2001 400ex timing help
Old Feb 14, 2009 | 09:38 PM
blackngold1982's Avatar
Default 2001 400ex timing help
the timing chain slipped and hit the piston.so i had to replace the valves and chain. well when i replaced the valves the first time the quad was atleast trying to start. it would sputter then cut out. so i pulled the head again to see how the valves were seating. the werent seating to well so i had to do some more hand laping. now it wont even try to start. i think im not getting it timed right. so if anyone can help please do.
Old Feb 15, 2009 | 06:30 AM
Loshe191's Avatar
Make sure the flywheel is on the T mark for top dead center.The cam sprocket will have 3 lines on it. 1 points up the other 2 line up with the top of the head and the lines face out away from cam. Also make sure the flywheel key did not break.
Old Feb 15, 2009 | 09:44 AM
how do i know when its on tdc. isnt there a compression stroke and exhaust stroke?
Old Feb 15, 2009 | 12:16 PM
300exStroked's Avatar
When the T through the eyelet is there, Thats top dead on compression i believe, Its the correct one. Then align the timing marks up on the head as Loshe said.. The lobes of the cam will then be pointed down. Get it as close to level as possible with the head.. it won't be exact, but pretty close.. Mine is set a touch forward because thats as close as they would line up.
Old Feb 15, 2009 | 05:09 PM
i tried that and it still wont start.i even reset the vavle lash.
Old Feb 15, 2009 | 05:57 PM
juttin_15's Avatar
pull the spark plug and hold your finger over the hole if it blows your finger off it is on compression if not it will blow a little air not much.
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Ramman1
Jun 16, 2016 09:07 PM
yambam13
Jul 4, 2015 01:49 PM
