HELP I NEED VENT HOSE CARB. DIAGRAM on 400 scrambler
Old Feb 15, 2009 | 10:17 AM
blackhawk_911's Avatar
Default HELP I NEED VENT HOSE CARB. DIAGRAM on 400 scrambler
Hey yall wuts up, I just got my first scrambler 400 2002 2x4...I Just had the motor re-built and I needed to know where the vent hoses from the carb. "plug" into...I suppose there is 2 (vent) hoses coming from the carb the one with the "check valve" on it, where does it plug into...I have the manual but no help there if anyone can help I will be very grateful for like a diagram or sumthing...thanks
Old Feb 15, 2009 | 11:11 AM
Just vent the two lines on carb body up under tank,throw away the "check" valve as it usually falls off anyway,and just a simple vent at bottom of carb for the overflow vent!
Old Feb 15, 2009 | 03:28 PM
nvm i got it
Old Feb 15, 2009 | 03:29 PM
thankx for the info.
Old Apr 24, 2017 | 09:46 PM
25Malachi's Avatar
Default Polaris 400 scrambler 2002 4x4
pols
I have the same problem I have a 2002 400 scrambler I've been working on I noticed that the carb has two hoses coming from it but I have no clue where they go and it doesn't seem like the oil is mixing with the gas on it I don't know what to do!
Old Apr 25, 2017 | 02:55 AM
Run separate hoses. Throw away any check valve. Zip tie the vent line(s) to the throttle cable or choke cable and let it terminate over the tank bracket.Run a separate overflow/drain line for the carb bowl and extend it past the bash plate. This set up pictured on the two strokes wasn't necessary and just confused people. If you suspect the oil pump,pull the pump cover and see if it's operating ok. If it's corroded as many have done,block off the injector line at the intake manifold and premix.
Attached Thumbnails HELP I NEED VENT HOSE CARB. DIAGRAM on 400 scrambler-carb-1.jpg
Old Apr 29, 2017 | 02:58 PM
25Malachi's Avatar
Default Bogging with throttle
Thanks so on the same 2002 400 scrambler I went ahead and rebuilt the carb and when I hit the throttle it Boggs down and dies what could it be
Old Apr 29, 2017 | 03:54 PM
This can either be from too much fuel or not enough,float level off,wrong jets,trash still in the carb,etc. Plus check that the tank vent line is not kinked and good fuel flow to the carb and carb vent lines are open. Look over the carb section pdf from the manual on you VM34 carb.It may be something simple that you've done wrong especially in the slide needle assembly that people have assembled wrong before. https://www.google.com/url?sa=t&rct=...U2gGlaHJWSIlbA Wouldn't hurt to do a compression check to see what condition the top end is in also.
fordfaithful21
Dec 7, 2015 05:52 PM
bvolks
Sep 13, 2015 12:57 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
1000gade
Sep 9, 2015 03:35 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
