Clutch offset question
Old Feb 15, 2009 | 10:41 AM
allenrw's Avatar
Default Clutch offset question
I am replacing the transmission on a 1997 xplorer 300 and the manual says to check the clutch offset and alignment. I have access to a full machine shop and would like to built the alignment/offset tool but can't find anywhere what the offset is (have seen 1/2" and 5/8" in some forum posts) or where it is measured from, although it looks like in the manual it is from the inside edges of the drive and driven pulleys.
Old Feb 15, 2009 | 11:03 AM
I wouldn't worry about building an alignment tool! After replacing transmission install original spacer washers behind driven clutch and check if belt is fairly centered on front clutch with equal space on each side of belt against clutch sheaths. Plus if not creeping,usually pretty close. If offset too much or too little,can add or remove spacers behind driven clutch!
Old Feb 15, 2009 | 11:14 AM
allenrw's Avatar
I used a different transmission and this ATV was beat on (and worked on badly, that is why the replacement tranny) by the previous riders. Being that I have to assemble the whole thing and get it running then take it apart and guess at the correct shim then put it together and hope it is right, I'd rather have the tool and know it is done.
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
