idle speed?
Old Feb 15, 2009 | 01:50 PM
skipper90's Avatar
Default idle speed?
I have a 2003 AC 400 automatic atv. Can anyone tell me how to adjust the idle speed?
Old Feb 15, 2009 | 09:38 PM
swampyjunior's Avatar
Default idle speed?
Should be a black **** on the end of a small flexible cable (about 2-3inches long) on the right hand side of the carburetor. (on your right if you are sitting on the seat). If you remove the seat it is easier to see it.
Clockwise turn = increase RPM
Counter Clockwise = decrease RPM
Service manual suggests that you turn it past the desired RPM and then turn it down to the desired setting.
Engine has to be at normal operating temperature before making any adjustments.
RPM's should be between 1250-1350. I adjust my manual tranny CAT so that it does not jerk when I shift into first from neutral or from neutral to 1st gear.
It also seems like I have to set it a little higher in the winter and a little lower in the summer.
Hope this helps
SJ
Old Deer Hunter
Sep 2, 2015 01:39 AM
dwhipper61
Aug 27, 2015 11:01 AM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
