Honda rancher 350 brakes
Old Feb 16, 2009 | 03:09 PM
bigjake34452's Avatar
Default Honda rancher 350 brakes
ok, ive done some searching but havent come up with anything. do i need a special puller to remove the front brake drums? btw its a 2003 honda rancher 2wd.
Old Feb 16, 2009 | 05:08 PM
Gimpster's Avatar
Remove the axle nut in the center of the hub.
They should slip right off
----- Gimpster -----
Old Feb 16, 2009 | 05:42 PM
really? dang, i cant get them to budge, not even with some taps with a hammer.
Old Feb 16, 2009 | 06:31 PM
Turfguy's Avatar
Probably rusted.
Old Feb 16, 2009 | 09:19 PM
whitelightnin3006's Avatar
Try rolling that thing forward or reverse while in neutral, it should move pretty easily.
Heres a couple of ideas though.
If it dont roll easily, use the brake adjusters to loosen the brakes, they are in there behind the little red plug that is on the wheels. You will have to roll the fourwheeler til you can see what looks kinda like a sprocket inside there that can be turned with a screwdriver. Kinda hard for me to explain but you will see what im talking about.
Second, its alot easier and you can get more pull if you leave the tires on the hubs, and just remove the axle nut from the middle. That gives you something alot bigger to grab onto.
good luck
Old Feb 17, 2009 | 08:26 AM
hmm, ill try it with leaving the tires on the hub, that sounds like a good idea. just to clear things up, when i said they cant budge, i meant taking them off, they spin very freely, just trying to do the wheel bearings.
Old Feb 17, 2009 | 11:15 AM
well thanks for the help guys, i needed a hub puller, got them off that way.
Old Apr 17, 2017 | 10:48 AM
msosebee's Avatar
Default Same problem
good luck
I had the same problem when I came here and saw your reply. I did just what you suggested and it worked. However, when I got the drum off I noticed their were two adjusters. My question is when I put the new brakes on, do I need to adjust both adjusters and if so, how tight?
Old Apr 18, 2017 | 02:07 AM
Very old post, but you do need to adjust both adjusters. They are almost always seized and need removal, freeing up and greasing when you have the drum off. I always adjust until the adjuster won't turn, then back off until the drum is free to rotate, perhaps a little drag. This is easiest with all four wheels off the ground on a 4WD 350.
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Scottma518
Jul 16, 2015 09:19 PM
timster911
Jul 13, 2015 01:57 PM
Scottma518
Jul 10, 2015 12:42 AM
