raptor 700 speed sensor
Old Feb 19, 2009 | 03:24 PM
skinindustries's Avatar
Default raptor 700 speed sensor
ok guys im new to the forum so i hope someone can help me out. i did the speed sensor thing about 2 weeks ago and somehow it got all messed up now it has no spark. i have tried everything i tried to find the connector to the baby blue wire and i found one close to it but i guess it dont work anyone have any idea on what to do???
Old Feb 20, 2009 | 07:25 PM
no one know anything come on guys
Old Feb 20, 2009 | 07:26 PM
jkrno's Avatar
what year
Old Feb 20, 2009 | 09:21 PM
2006 raptor 700r bone stock
Old Feb 25, 2009 | 12:10 AM
scottd's Avatar
Just get a performance ECU off one of the vendors in ebay for around $100 and be done with it. These eliminate the 5th gear ignition retard, add an improved timing curve, and also allow you to adjust fuel mixture for your particular mods. All these other "disconnect sensor and cut a wire" claims are a joke. I tried them all with no results, and still got the check engine light on. Got tired of hacking up my wiring harness. You get what you pay for!
Old Feb 25, 2009 | 12:26 AM
yeah i got a busted *** quad ha. and by ecu do you mean a PC3 or a new cdi? the bike is bone stock. i might get a new wiring harness from this guy who is charging 50 bucks shipped. and i have another problem my solenoid make a buzzing noise whats up with that?
Old Feb 25, 2009 | 08:59 AM
scottd's Avatar
Yes, I'm talking about the CDI. If your wiring harness is that messed up, then I would just replace it at this point. Sounds like you may have a bad solenoid, but make sure your battery is fully charged and the connections are good first.
Old Feb 25, 2009 | 12:25 PM
yeah i had the battery on the charger al day yeasturday when i was working on my banshee and the needle didnt move at all. i think my battery is junk. so i a mgoin to get a new battery and a new harness see if this helps it should.
Old Feb 25, 2009 | 01:39 PM
bigned1904's Avatar
i myself would not leave that speed sensor unpluged for any ammount of time.after a little while u will get check engine lights and such. if u want to get rid of that get a dynatek programable ingition. the raptor 700s stock timing curve sucks. and i would HIGHLY recomend getting one from daniel at high desert dyno. he sells them with custom timing curves. that will make a big difference. but sence u are bone stock there r better mods for the cash.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
poutlaw525
Sep 9, 2015 03:19 AM
black_thunder
Sep 6, 2015 04:41 PM
