sportsman 500 awd.help!!!
Old Feb 26, 2009 | 08:13 PM
judsharley3's Avatar
Default sportsman 500 awd.help!!!
2000 sportsman 500. Awd was working fine,just had a bent axle,so I replaced the axle with a new one,also put in new strut seal and new hub seal.Now I put everything back together several times so I know its back together right,but the hub on that side wont lock in
Old Feb 26, 2009 | 08:26 PM
Check that power is going to hub(connectors under front cover, gray and brown small wires for both sides) Also 3 tabs on armature plate must line up correctly on hilliard,torque on hub nut 12 foot pounds.
Old Feb 26, 2009 | 08:37 PM
checked power already,armature plate is magnetized to strut and the three tabs on plate are in slots on hilliard . is the 12ft lbs that critical?
Old Feb 26, 2009 | 08:42 PM
xplorerman's Avatar
yes the 12 ft pound is very critical
Old Feb 26, 2009 | 09:01 PM
Thanks I will try that as well...I have tried everything else
Old Feb 26, 2009 | 09:22 PM
GTSnoRacer's Avatar
Can anyone tell me if it's normal for the front wheels to spin in 2x4 with the wheels off the ground (on a jack not a wheely), they don't spin when I hold them.
Thanks
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
