powering fan with acc plug
Old Feb 27, 2009 | 06:34 PM
pedals's Avatar
Default powering fan with acc plug
Just wondering if there would be any problem powering my fan by connectiong it to a extra acc plug that I have and plugging it into the acc plug spot. I'm trying to find out why it's not turning on by itself instead it's overheating but that's another issue!!!
Old Feb 27, 2009 | 07:09 PM
eggenz7's Avatar
shouldnt be any problem at all. its just a 12v fan running from a direct connection to a 12v source
Old Feb 27, 2009 | 07:11 PM
pedals's Avatar
thanks...just wanted atleast someone elses 2 cents incase I was missing something obvious!
FAAMECH's Avatar
Its sounds to me thateither your temp switch is bad or your fan is dead.........I believe if you disconnect the plug on your temp switch the fan should kick on .....if it does your switch is bad.. If not check the power going to the fan.......
Old Feb 27, 2009 | 07:28 PM
pedals's Avatar
when I unplug the temp sensor the check engine light comes on after about 10 sec but that's it not hot light and the fan doesn't have any power. The fan works when i hock it up directly so there's something inbetween that is not working
Old Feb 27, 2009 | 07:48 PM
FAAMECH's Avatar
I think there was a recent post here here about NAPA having a temp sensor cheaper than Polaris..Might be worth a try.............other thing you could do is heat the engine up and see if the switch is closing using a ohm meter
Old Feb 27, 2009 | 07:57 PM
pedals's Avatar
how abouts would I do that. I took the thermostat out and dropped it in some boiling hot water and it's working fine. any other ideas on what I can test to better find out what's wrong.
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
chammerbeck
Jul 17, 2015 08:06 AM
Unzzy66
Jul 11, 2015 10:01 PM
tweeder
Jul 5, 2015 01:57 PM
