Sportsman 500, no electric start, lights and instrument panel flicker at higher rpms
Old Feb 28, 2009 | 04:01 PM
BJ8807's Avatar
Default Sportsman 500, no electric start, lights and instrument panel flicker at higher rpms
03-04 Sportsman 500 H.O. I am have some electrical problems and would appreciate any help you guys have to offer. I can pull start it but when i turn the key to start there is just a clicking noise coming from a solenoid or relay, not sure what it is but it has a battery cable to it. When i push the winch button the same thing clicks. When i rev it up the lights flicker and the instrument panel goes off and the lights dim at any rpm. Any ideas?
Old Feb 28, 2009 | 05:41 PM
chuck_raduenz's Avatar
sounds like the battery is junk.
Old Feb 28, 2009 | 05:43 PM
BJ8807's Avatar
Thats what i thought but i hooked up a lawn mower battery and it still wouldnt turn over
Old Feb 28, 2009 | 05:58 PM
humm. the winch clicks also? just outa curiosity you try to jump start it with abttery cables?
Old Feb 28, 2009 | 06:16 PM
BJ8807's Avatar
i used jumper cables and i also tryed batter charger
Old Feb 28, 2009 | 06:23 PM
so with trying all that the winch and starter still wont work? but it starts and runs fine when recoil starting it?
Old Feb 28, 2009 | 06:28 PM
BJ8807's Avatar
yeah it runs fine pull starting it but the instruments go on and off and when its idling the headlights seem to get dim. and im not exactly sure what the part is called that clicks but its like 1" square that has two posts and a battery cable going to it and a cable that goes from this part to the starter solenoid. do u know what this part is?
Old Feb 28, 2009 | 06:35 PM
starter solinoid. that is the part that clicks when you try to start it. ok. well try this. on the starter solinoid. there a 2 cables im guessing yours a red. but one comes from the battery and the other one goes to the starter. take something to jump power from the battery to the starter side of the solinoid to see if the starter will turn over the engine. if that dont work im guessing its the starter. what happend prior to this all happening? it also sounds like there may be a connection issue between the battery and the atv.
Old Feb 28, 2009 | 07:01 PM
BJ8807's Avatar
well i took a screwdriver and crossed them but didnt work and if thats the starter solenoid then whats the part farther back that has i think four posts and 4 thick wires going to and from it? would it be the voltage regulator
Old Feb 28, 2009 | 07:07 PM
that sounds like your winch solinoid. and if it didnt turn over while jumping it sounds like the starter. what happend prior to this all happening?
