02 polaris sportsman
Old Mar 2, 2009 | 04:06 PM
jrjordan82's Avatar
Default 02 polaris sportsman
i have a 02 polaris sportsman 500 that i had to replace the cam and rocker arms on. after i done this i can not get it to start now. it keeps blowing air back into the carb and can not figure out what is wrong with it. pretty sure the timing is set correct on it cause i went off the T mark then set the cams. please help
Old Mar 2, 2009 | 04:15 PM
Cam index pin straight up when you replaced chain and sprocket on cam? valves at .006 intake and exhaust? Was it doing this before you replaced cam (rings,low compression?) Did you reset cam chain tensioner and pull on recoil to let tensioner adjust to chain?
Old Mar 3, 2009 | 07:19 AM
jrjordan82's Avatar
i lined everything back up just like it says in the book to do. i had taken it to a polaris dealer and i went to pick it up cause it was taking them to long to get the parts and they pretty much just tossed it all back together cause would not even start when i picked it up like it was when i dropped it off.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
