over charging sp 500
Old Mar 6, 2009 | 03:43 PM
xplorerman's Avatar
Default over charging sp 500
hello i have a 2003 sportsman 500 that is over charging when at idle it is 13 volts but when you rev it up it is putting out up to 18 volts at times what should i start with i have looked at past posts and i think the regulator but i dont know
Old Mar 6, 2009 | 04:48 PM
eggenz7's Avatar
i would definatly check the regulator. easiest way is to trade witha buddy and see what happends.
Old Mar 6, 2009 | 07:55 PM
<div class="FTQUOTE"><begin quote>Originally posted by: xplorerman
hello i have a 2003 sportsman 500 that is over charging when at idle it is 13 volts but when you rev it up it is putting out up to 18 volts at times what should i start with i have looked at past posts and i think the regulator but i dont know</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] If over charging (past 15volts) will fry battery if reg/rectifier not changed out! battery usually will get hot and cells will short out over a short period of time!
Old Mar 6, 2009 | 09:28 PM
xplorerman's Avatar
is thear any way to test to find out for shure i dont have any frends with polaris to swap the parts to try them
Old Mar 7, 2009 | 07:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its most likely got to be the recifier thatis bad since that is what controls the amount of voltage. imo.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
