Engine Timing???
Old Mar 6, 2009 | 11:08 PM
Jeff_85200M's Avatar
Default Engine Timing???
anyone know a quick and effective way of putting a 1985 Honda 200M engine on its timing??
Old Mar 7, 2009 | 11:47 AM
odysseyjunk's Avatar
iirc, the cam has a mark, and with the crank, you can put a screwdriver down the spark plug hole and turn crank until piston is all the way to the top.... this is tdc. as far as the cam, the mark should be in a place where none of the lobes is pressing down on the valves, but the intake is just about to press down.....youll see the mark somewhere around there!
done this on many a car where i couldnt find crank timing marks hehe......
Old Mar 7, 2009 | 11:53 AM
haha thanks man
Old Mar 11, 2009 | 08:49 PM
rangerboy351's Avatar
well if its anything like a 200s make sure its on tdc make sure the lobes are faced down on the cam make sure the dot next to cam sprocket bolt is inline with the head notch and ck the fly wheel markings i think their is a f and a t use the t for cam timeing
Old Dec 24, 2012 | 03:57 PM
greg56's Avatar
Unhappy timing marks ?
can you show a picture of a marshin power 198cc motor timing cam and flywheel
Old Oct 15, 2013 | 12:12 PM
kormos_93's Avatar
Like the others said, just make sure the marks are lined up. I found this video very helpful:
Old Oct 30, 2013 | 12:02 PM
MonkOFox's Avatar
http://www.oscarmayer.net/atc/manual...shopmanual.pdf if you want the manual to reference.
SOLOLUCKY
Oct 4, 2024 09:09 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
kevbowe
Jun 1, 2015 01:17 AM
