99 HONDA FOREMAN 450ES SHIFTING PROBLEM
Old Mar 7, 2009 | 02:08 PM
MUDCHICK30's Avatar
Default 99 HONDA FOREMAN 450ES SHIFTING PROBLEM
got a 99 honda foreman 450es that will not shift. but manually shifting it will go to neutral and first but after first gear it is just a black blinking line. i have replaced the angle sensor, speed sensor, ecu, traced all wires and ohm out back to ecu. any suggestions?
Old Mar 9, 2009 | 02:30 AM
Gimpster's Avatar
Do a gear position switch test
If it checks out, remove the shift control motor and check if it spins both directions with voltage hooked to the wires both ways with little effort.
The pre 2002 electric shifts can be a pain to diagnose as they do not display codes
Found quite a number of bad shift control motors that shut down the electric shift system because of water in them, corrosion, bad armeture contact via bad brushes or arcing out a spot in the armeture
My 01 450 has eaten 2 shift motors since I bought it. Even recieved a defective brand new shift motor from Honda while fighting shift issues on mine
----- Gimpster -----
Old Mar 9, 2009 | 07:35 PM
MUDCHICK30's Avatar
Thank you very much. There was mosisture present. Cleaned and it fixed the problem.
Old Mar 9, 2009 | 07:48 PM
leroyb28564's Avatar
i have a 06 300 rancher es,and i'm having real problems with the shifting,the neutral blinks twice and won't go into gear i need help on this
Old Jun 3, 2012 | 11:41 AM
mike123's Avatar
Default 1999 450es issues
my ecu is hot to coutch. i have replaeced motor & angle sensor. do i need a new ecu?
Old Jun 4, 2012 | 06:37 PM
JohnHS's Avatar
Hello all - I have a similar problem developing on my 2000 Foreman 450ES - can anyone tell me the best way to get at the shift motor/angle sensor? What if anything has to be removed? Thanks for any help!
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
neilbedwell
Nov 10, 2018 11:02 AM
sara durrant
Jul 6, 2015 05:32 PM
lovinhonda
Jan 25, 2000 09:17 PM
