Wolvering Idle Adjustment Screw
Old Mar 10, 2009 | 03:19 PM
Yamaha74's Avatar
Default Wolvering Idle Adjustment Screw
I have a 2004 Yamaha Wolverine and I am not sure where the idle adjustment screw is. I thought I knew but the screw I am turing I think might be a throttle stop screw according to my service manual. There is a screw on the left side of the carb right under the throttle cable housing. It is a goldish color screw that can be twised with your fingers. It doesn't seem to adjust the idle but if I turn it to far in or out the motor will run real bad and die out. So can someone shed some light on this and tell me where the idle adjustment is at? If I need to take pictures of it I will.
Old Mar 10, 2009 | 08:28 PM
JLsparky7's Avatar
There is only going to be 2 adlustable screws on the carb. One is the fuel/air adjustment and the other is the idle rpm adjustment. Sounds like your adjusting the wrong one.
Old Mar 11, 2009 | 06:28 AM
Yamaha74's Avatar
I know where the fuel adjustment screw is because I actually swapped it out with a extended one so I didn't have to use the special tool. The other screw I am turning I thought was the idle adjustment but it just doesn't seem to act like an idle adjustment screw.
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
ghost civic
Jul 30, 2015 04:09 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
