04 400 sportsmen ,no speedo ,4by , lights , but fan and it runs
Old Mar 11, 2009 | 08:30 AM
yaK's Avatar
yaK
Default 04 400 sportsmen ,no speedo ,4by , lights , but fan and it runs
any ideas where to start ?It just went out while plowing ....i backed up the i had no 4 by and no speedo. it still starts the winch and the fan both work but no lights.Is there a fuse? Could it be the speedo went?
yak
Old Mar 11, 2009 | 10:26 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is this an 04 or 04.5 year? just wondering if it had a bad ecm. if not sounds like the speedo might be the culprit. does any part of the speedo work at all or just the speed sensor the issue?
Old Mar 11, 2009 | 03:21 PM
yaK's Avatar
yaK
its an 04 ....and the whole speedo is blank.
Old Mar 11, 2009 | 03:58 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check the wire plug ins in the back of it? other then a bad connection i would have to guess that the speedo it self is junk.
Old Mar 17, 2009 | 02:13 PM
yaK's Avatar
yaK
ok ... i found the problem. I found a broken wire[a brown one] leading from the headlight pod down into the front of the machine. It broke from all the turning of the bars i guess.
Anyway thanks STEN!
whitty
67
Feb 24, 2021 02:52 PM
jayking232003
Dec 4, 2019 09:38 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Rooky
10
Jun 23, 2015 09:35 PM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
