Help with Beartracker
Old Mar 12, 2009 | 04:42 PM
FFwilliams's Avatar
Default Help with Beartracker
I have a bear tracker 250cc. I am not sure of the year but I know it is 2001 or 2002. I am having trouble with the carb. I just ordered a rebuild kit for it but not sure of the setting once I am finished. Also I am having trouble disconnecting the throttle cable from the carb itself. Not sure how to get it apart to remove the carb. The bike does run, but only on half choke. Also when I give it gas it cuts out right away. Any Help?
Old Sep 7, 2009 | 06:30 PM
tigertank's Avatar
Hello, did you find out how to disengage the throttle cable, because i have a 2000 bear tracker with the same delema, thanks.
Old Sep 7, 2009 | 07:05 PM
Malachi's Avatar
I don't have a beartracker but from this picture if you pop off the cover labeled #30, you should be able to see how the cable is connected and remove it. If not, post a picture of your carb with that cover removed and I'm sure someone could help.
Old Sep 8, 2009 | 02:57 PM
tigertank's Avatar
Thanks Malachi, nice picture. Yes, i took that cover off, but still looked frightening in there lol. Maybe i'll get the courage up to see more, thanks.
Old Oct 1, 2009 | 09:26 AM
tnvols88's Avatar
Default carb help
I see the picture of the breakdown....but still can't figure out how disassemble the throttle cable...how do i do that?
HunterExplorer
Mar 5, 2002 06:43 PM
doggster
Sep 3, 2001 12:43 PM
beartracker14
Mar 23, 2001 12:03 AM
Rebel
Aug 26, 1999 12:11 PM
