TRX90
Old Mar 17, 2009 | 09:30 AM
randyroo96's Avatar
Default TRX90
The motor starts fine in the choke position, But when I take the choke off it dies.
Old Mar 17, 2009 | 10:05 AM
corcan1's Avatar
Default TRX90
quick guess here but it sounds like the low speed jet in the carb needs cleaning.
Old Mar 17, 2009 | 10:48 AM
budedm's Avatar
Default TRX90
Mine did that once and I found out that the gas cap breather was clogged.
Old Mar 18, 2009 | 12:57 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default TRX90
These are prone to getting their idle (slow/pilot) jet gummed up because of stale gas. This means that you have to much air for the amount of gas, and that leaves you lean. The choke cuts down on the amount of air, and temporarily fixes the problem. Most likely all you need a good carb cleaning, and pay particular attention to that jet.
Otherwise, it could be a leak in the air filter or the intake boot. It is important to eliminate this possibility, as it can pass dirt into your engine.
Ak mike
Sep 5, 2015 10:23 PM
Ak mike
Aug 22, 2015 10:39 AM
Gvidon
Apr 9, 2013 03:12 AM
IWL BCNU
Jan 18, 2008 11:03 AM
RandomRyder
May 14, 2005 12:29 AM
