Does Yamaha make a speedo kit for Big Bear 400?
Old Feb 12, 2001 | 01:46 PM
Kman's Avatar
I have a 2001 Big Bear 400 and was wanting a speedometer kit for it, but my dealer says they don't make them for the Big Bear, only for the 2000 Kodiak. I am almost sure I saw someone on this forum who had the speedo for the Big Bear. Any help would be appreciated.
Kman
Old Feb 14, 2001 | 10:59 PM
Javahere's Avatar
Go to www.missionyamaha.com they have the kit for the Big Bear.The 2000 model is latest one they list, I'm not sure of any major changes for 2001 Big Bear,not many if any.They list the one for the 2000 for 149.95.
Java
2000 Kodiak
Old Feb 14, 2001 | 11:56 PM
drincbud's Avatar
yamaha does make one for the 2000 big bear part# 5FU-W0081-00-KT.the book doesn`t list a price for it so contact a dealer..hope this helps u
Old Feb 15, 2001 | 12:41 PM
Kman's Avatar
Thanks for the replies. Dang, that's expensive. Anybody know of an aftermarket kit?
Thanks,
Kman
Old Feb 15, 2001 | 04:27 PM
FKNA's Avatar
After reading these posts I decided to call my dealer. They charge only $100 for the kit. So, check with your dealer now that someone has given you the part #
Old Feb 15, 2001 | 05:52 PM
Kman's Avatar
Thanks, I'll call my dealer now that I have the part # and see what he charges.
Kman
Old Feb 25, 2001 | 09:43 PM
BB007's Avatar
I purchased a speedometer for my 2000 Big Bear from my local Yamaha dealer. At first they were not sure if one was available but after they checked out their parts catalog sure enough there it was. I paid $145.00 for mine. You have to remove the right clutch cover and knock out the plug in the back of the cover. The kit gives you a new gasket and a gear to install then you just put the cover back on and the cable slides into the back where the plug was removed. The job takes about 1-2 hours. Good luck. BB007
Old Feb 26, 2001 | 12:02 AM
minehunter's Avatar
Or, you can go down to your local Walmart/Kmart and get a digital bike speedometer and adapt it to your Big Bear. I put one on a friends, It took about 45 minutes, cost $11.00. They have the following things on them, Speed, Max speed, Avg speed, Time, Odometer and Elapsed time. The display is only about one half inch, but they are quite readable at just about any speed. All you have to do is make sure that you understand that there are two wires in the insulation and extend them both. Go to Radio Shack and get a very strong small magnet. Attach the magnet to the front stub shaft at the differential with silicone adhesive, mount the pick up, and you're ready to go. Total cost less than $20.00.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
neilbedwell
Nov 10, 2018 11:02 AM
Rooky
10
Jun 23, 2015 09:35 PM
traumajunkie
Jun 14, 2015 01:55 PM
volsgo30
Jun 4, 2015 06:07 PM
