The warrior compaired to its brothers???
Old Feb 12, 2001 | 03:44 PM
warrior89350's Avatar
I have a 89 warrior and have not taken out of my neighbor hood yet. I was woundering if any stock warrior owners can tell me the quads in the field around the warrior what quad can the warrior beat?? Not to mention the blaster,mohove,the trail blazer. and all the other quads like it!!!1
Old Feb 12, 2001 | 05:48 PM
dawarriorman's Avatar
warriors will beat most every polaris!
Old Feb 12, 2001 | 07:30 PM
MilleniumScr500's Avatar
HAHAHAHAHA.........I don't think so
It will not beat either scrambler I don't think it will beat the explorer or sportsman but I could be wrong....But the other's I think it will
But who cares anyway. I just do not like false info.
I do think it will beat a 300ex because of the extra gear and more cc's but I am not to sure
Old Feb 12, 2001 | 08:12 PM
HondaManMyers's Avatar
In an article of dirt rider it said that the worrior is faster than the ,in order from least behind to most,Blaster was closest, then the 300 then the mojave.
Old Feb 12, 2001 | 08:32 PM
54warrior's Avatar
i have a 96 warrior, and unless you run the ***** out of it, a 300ex will run even with it, i am 250 lbs though so i'm sure that makes a difference. unless you are flat out drag racing, top speed doesn't matter, most of it is in the rider, i can beat some guys on 250R's through the woods
Old Feb 12, 2001 | 11:02 PM
morrisot's Avatar
I have owned 3 Warrior's in my time (88,89,and 94). Over all I feel that they are a fairly solid machine. The only thing that I would say is its brother/competion is a 300ex. Being that it is a 4-stroke and close to the same size and type of machine.
In my experience the Warrior will beat a 300ex but it is nothing to write home about. Coming off the line the warrior might have a slight jump.(depending on the rider) It will eventually pull away slightly from the 300ex on top end.
One thing to note: The warrior, bone stock is HEAVY compaired to the 300ex. But the 50cc extra helps make up for that. Both bikes have alot of +/-'s when compairing the two. Alot of it depends on which feels more comfotable to you.
Pehter
Oct 3, 2024 11:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
cboler9
Sep 24, 2015 08:35 PM
bvolks
Sep 13, 2015 12:57 PM
