help honda mechanic!
i have an trx 400 foreman 1998 and it will shift into reverse and 1st gear but will not go into any other gear? i was riding it and it was working then i stopped and put into neutral and thats when it started. thanx i appreciate all the advice
skitz80 is it an ES , ESP or manual shift model ? , the reason i ask is that honda has had a good bit of woes with the ES and ESP models ever since they fist came out ; but if's it's a manual shift it could be a worn shift fork inside the tranny case , a simple cable adjust or even clutch adjustment !
Hope this help's , and welcome to the forums........
I would remove the clutch cover and check the "drum shifter" to make sure 1 of the posts isn't broken off .. When 1 of the posts break it will shift fine up & down it just won't go past the gear with the broken post ..
Here is a broken one ..
Aug 5, 2015 02:10 AM
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
