help honda mechanic!
Old Mar 22, 2009 | 12:44 AM
skitz80's Avatar
Default help honda mechanic!
i have an trx 400 foreman 1998 and it will shift into reverse and 1st gear but will not go into any other gear? i was riding it and it was working then i stopped and put into neutral and thats when it started. thanx i appreciate all the advice
Old Mar 22, 2009 | 01:46 AM
Williebee's Avatar
skitz80 is it an ES , ESP or manual shift model ? , the reason i ask is that honda has had a good bit of woes with the ES and ESP models ever since they fist came out ; but if's it's a manual shift it could be a worn shift fork inside the tranny case , a simple cable adjust or even clutch adjustment !
Hope this help's , and welcome to the forums........
Old Mar 22, 2009 | 03:57 AM
HondaMechanic's Avatar
I would remove the clutch cover and check the "drum shifter" to make sure 1 of the posts isn't broken off .. When 1 of the posts break it will shift fine up & down it just won't go past the gear with the broken post ..
Here is a broken one ..
Old Mar 23, 2009 | 08:31 PM
skitz80's Avatar
is this part behind the clutch? and is it nescessary to remove the engine or should i have an service center do it? i mean is this something that can be done with the manual?
Old Mar 23, 2009 | 09:13 PM
You have to remove the clutch cover and both clutches to service the gearshift assy ..
greg74
Sep 10, 2019 03:03 PM
Aug 5, 2015 02:10 AM
DeFox500
Jul 26, 2015 06:32 PM
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
