Cold and Warm idle speed
Old Mar 22, 2009 | 09:54 AM
TrailblaznSonny's Avatar
Default Cold and Warm idle speed
I have a 350 Bruin that runs great. It starts cold very quickly but it has to run about 5 minutes or it will die at idle (no choke) If I turn the idle speed up then when it warms up it idles way to fast. I have had this bike for 5 years and it just started doing this. I use to be able to choke it for about a minute then take off the choke and it ran great from then on. Any ideas?? Carb is clean valves are adjusted...
Old Mar 22, 2009 | 04:31 PM
JLsparky7's Avatar
Take the carb apart and clean it. Could have something hanging up in the idle jet.
Old Mar 22, 2009 | 05:38 PM
Thanks Sparky, but I took the carb down and cleaned it really good, No change. I just found my primary side of my ignition coil is out spec by about double. This might
address one of my problems with a miss at idle, Not sure about the idle speed problem though. Any more help would be appreciated...
Old Mar 23, 2009 | 08:02 AM
JLsparky7's Avatar
Try air/fuel mixture screw. Should be about 1.5-2 turns out. Your probably on the rich side.
Cummins Driver
Sep 11, 2019 01:22 PM
scram5050
Aug 19, 2015 02:19 AM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
