Smoking 250ex
Old Mar 24, 2009 | 08:23 AM
lbown71's Avatar
Default Smoking 250ex
I have a 2002 250ex that is stock. It is smoking quite a bit not only on start up but while riding. It is white smoke and guess it could be oil being burned. Any ideas on how to fix this? New piston rings or is there an easier solution?
thanks
Old Apr 24, 2009 | 02:32 PM
brungardt's Avatar
get a compression tester if you dont have one and check it...if its around 150 PSI your ok... but if its way lower you will need new rings...if it is 150 or higher you might need valve seals instead.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
