300 carb ?
Old Mar 25, 2009 | 05:11 PM
gsjeepxr's Avatar
Default 300 carb ?
just put in a 128 main with moose filter and drilled lid. im waiting on my fmf system in the mail but when i went to start it, it revd up and stayed up no matter what i adjusted. should the pipe solve this problem?
Old Mar 25, 2009 | 09:16 PM
cherokee99's Avatar
Default 300 carb ?
sounds like an intake leak. make sure all your clamps and fittings are tight. pipe will help, just jetting with stock pipe is a waste
Old Mar 25, 2009 | 09:30 PM
gsjeepxr's Avatar
Default 300 carb ?
will check that. yea the full system will be in friday, i just figured id try starting it with the bigger jet and she just revd up high. i thought i had it tight though. hopefully the exhaust solves that. its a full fmf powercore4
Old Mar 25, 2009 | 09:47 PM
cherokee99's Avatar
Default 300 carb ?
did you get the powerbomb header too? you can do a vaccume test on your intake, take u 2 munites.
pull off air filter, turn the kill switch to OFF position. place your hand tight over the intake and hit the starter switch-allow the engine to turn over once or twice so that a vaccume is created in the intake. the vaccume should last for 30ish seconds. if it does not you have a leak.
simple yet effective test. good luck
Old Mar 26, 2009 | 05:41 AM
gsjeepxr's Avatar
Default 300 carb ?
thanks il give that a try tonight. yes it comes with the powerbomb header but its not the one with a bubble in it next to the head.fmf said a 128-130 with the lid off so im hoping a 128 with the lid just drilled will work.
Old Mar 26, 2009 | 05:21 PM
wilson8305's Avatar
Default 300 carb ?
putting the exhaust on i don't beleive will change this at all, take carb back apart and make sure everything is right, make sure the spring is right, for where the cable pulls the cylinder up and down, sounds like the cylinder is staying up and not coming back down, beleive me, it's not the exhaust, and the jets will help a lil bit but not much without the pipe, good luck man
Old Mar 26, 2009 | 05:59 PM
gsjeepxr's Avatar
Default 300 carb ?
thanks, yea i didnt think just changeing the jet woulda caused that. pipe should be here sat i just wanted to get the jet in ahead of time biengs i had it riped apart to do plastics, 400 shock conv,exhaust,axle xtenders,nerfs,frnt n rear bumpers,tether n some other accesories. looks preety sweet for a 300. ill rip the carb back off and check it out. thanks again
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
