Polaris AGL Fluid
Old Apr 5, 2009 | 12:10 PM
DARETORIDE's Avatar
Default Polaris AGL Fluid
Does anybody know if the fluid has changed at all?? I need fluid and everything is closed today and i have some brand new fluid left and the a older bottle(Different shape) thats like half full...
They both say the exact same thing.... I just wanna know if I can mix them.....
Old Apr 5, 2009 | 12:42 PM
TLC's Avatar
TLC
The only changes I heard of was, the AWD Hillary Fluid for the old Twin hub set up is different from the current Single front differential Hillary fluid.
The motor old is not 0w-40 but 2w-50 or something like that now.
Old Apr 5, 2009 | 01:08 PM
NoJoke's Avatar
I would check the part numbers that are on the containers of the AGL.
Old Apr 6, 2009 | 03:59 PM
DARETORIDE's Avatar
thanks.... part numbers are same and i put some in a cup together and mixed perfectly so i used it...also when changing the fluid on 08 400 it says 600ml or something close to that in the manual.... is that when it is right full to the bolt?? So instead of measuring can i just fill it till it wont go any higher since it will just flow out??
Old Apr 6, 2009 | 06:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the biggest thing you cant do is put the non LT fluid in the adc which your 400 doesnt have so your al set there.
Cole Hadden
Jun 15, 2025 09:05 AM
NatePerz
Jul 27, 2015 03:27 AM
Sandman2.0
Jul 21, 2015 09:03 AM
maxjung
Jul 13, 2015 05:11 PM
rcappie4
Jul 10, 2015 04:54 PM
