Installing new throttle cable on 200 Beast
I can't figure out how to connect the throttle cable to the carb piston... the throttle cable is supposed to go through a small curved tube then into connect to the piston... the thing is, there is no way of getting the cable through this little tube, and where can I buy this little curved tube.... help.... and thank you
Welcome to the forum vandam!
Do you have the correct throttle cable for your machine? If you cant get the current cable thru the curved tube Im not sure how a new tube will help. Could you possibly post a picture of your carb/cable setup?
GregM
Mar 6, 2018 06:53 AM
200, atv, cable, carb, carburetor, chinese, connect, connection, cr, honda, installing, picture, throtle, throttle, xr
