1987 Polaris Cyclone
Old Apr 9, 2009 | 11:24 AM
ForevCyclone's Avatar
Default 1987 Polaris Cyclone
hello i'm new here so...hello.But what I am really here for is I just bought a polaris cyclone ran great but would not move (reason Being it had a clutch kit and he did not give it enough gas) my question is will this ruin my tranny or will it hold up okay? Because I had A TrailBoss and my tranny went?
Old Apr 9, 2009 | 11:34 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Sounds like it has the wrong kit for sure. If you can get it back to stock, and possibly just change the primary spring to a white, you should be ok.
I'm sure ftwflh would have the clutch answer for sure.
Get the clutch worked out and you'll have a nice little screamer.
Old Apr 9, 2009 | 11:43 AM
oh I can drive the thing around fine i was just wondering if it would ruin my tranny in the long run? Thanks for the quick response
Old Apr 9, 2009 | 11:45 AM
Supersock
Hired Gun!
Well, check the tranny fluid, just to be safe. When you say they weren't giving it enough gas, about how far on the throttle, or a estimate of the rpm range did it take to move it?
Old Apr 9, 2009 | 11:51 AM
I give it about half throttle I dont know how high the rpm is i would guess 5-6000 it is screaming (loud exaust)
Old Apr 9, 2009 | 12:05 PM
Supersock
Hired Gun!
Sounds a little too high in the rpm range. Could be they tried to make a clutch kit from another model work in it. If it's taking that much just to move it, I'd be more worried about the motor than the tranny.
Old Apr 9, 2009 | 12:07 PM
Supersock
Hired Gun!
Again, ftwflh is what I'd call an expert on the clutch of the 2 stroke Polaris. I'm sure when he sees this, he give you some solid answers.
Old Apr 9, 2009 | 03:37 PM
drlang's Avatar
They have a higher engagement from the factory, due to the pipe and porting. Personally due to to vintage, I would go thru the clutch to see how healthy (wear) it is. I want 1 of these where are you and would sell it? Also check engine mounts and belt for starters. Doc
Old Apr 9, 2009 | 08:15 PM
ftwflh's Avatar
Exactly what Doc said.GReat machines extreamly fast but do have a high engagment rpm.
Old Apr 10, 2009 | 04:24 PM
drlang's Avatar
This FTWFLH guy really knows his stuff
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Bulgin88
Jul 30, 2015 05:20 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
