1985 Honda 250es
Old Apr 13, 2009 | 03:00 PM
kpg's Avatar
kpg
Default 1985 Honda 250es
I pulled off the timing chain tensioner because of an oil leak,i put it back in and it ran good for about 30 seconds.It no longer had any power.I took it back out and kind of messed with it,put it back in the bike now it wont even start.Can anyone help?
Old Apr 13, 2009 | 03:17 PM
MadMel777's Avatar
you probably knocked the timing out of whack ... check the timing marks and see if its ok
Old Apr 13, 2009 | 03:24 PM
kpg's Avatar
kpg
How and where do i do that?
Old Apr 14, 2009 | 05:33 AM
HondaMechanic's Avatar
You have to remove the top cover to check timing... They it must be sealed when installed & valves adjusted .. If the cam chain slipped by removing the tensioner then it must be quite slack and probably needs to be replaced ..
Old Apr 14, 2009 | 08:08 AM
kpg's Avatar
kpg
So.....basically it needs a top end job on it?
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
