1999 polaris sportsman 500 awd trouble???
Old Apr 14, 2009 | 06:48 PM
cubswin1oo's Avatar
Default 1999 polaris sportsman 500 awd trouble???
Brand new speedo, awd light comes on in L, H, and R with key on. When bike is running Awd light will not come on. Also when the bike is put in H or L the R light on the headlight pod comes on. The bike also stalls in reverse without the reverse override switch pushed in.
Old Apr 14, 2009 | 07:53 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like maybe the trans switch may be messed up, or the override switch. just a guess.
Old Apr 14, 2009 | 08:43 PM
cubswin1oo's Avatar
Default awd problem, also bike modified
Also this bike has been snorkled. The radiator sits on the front rack, hence the main headlight pod has been bypassed and hooked into two spotlights. could this affect it operating properly?
Old Apr 14, 2009 | 09:39 PM
cubswin1oo's Avatar
Default awd trouble 1999 Polaris Sportsman 500 (snorkled)
Ok now after further review. With the key in the ON position, bike not running, I slide the awd switch to on and put in any gear. Awd lights up, I then start the bike in gear and it stays lit. As soon as I switch the gear from let's say L to H the light goes off and will not come back on. Keep in mind my reverse override is tiewrapped down cause if not the bike dies when put in reverse! Wow what a nightmare. I tried testing the 4wd the other day by lifting it and putting it on jackstands. No matter what only the rears turned. I tried sticking it in the sugarsand by holding front brake, while burying the rear tires, couldn't stick it. I just don't know if the red awd light is just not coming on to annoy me or what.
Thanks for any input,
Lenny
Old Apr 15, 2009 | 06:01 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it sounds like you have a few wiring messes. the override button not being pushed in will not just stall the bike. the awd button in the on spot will not make the awd work in reverse w/out pushing the yellow override button. this is why some people bypass the switch. so w/ the awd on you dnt have awd at all in any gear?
Old Apr 15, 2009 | 06:20 AM
Kerbbirds's Avatar
Unplug the black wire from the speed limiter box, follow wires from override button to the box. Also sounds like shifter switch is bad, I have wired around these, you have to supply power to the two wires that go to the front hubs, find a hot wire on the circuit board and run a jumper wire from it to the hub wires, the awd switch will still turn it off and on, Kinda hard to explain,hope this helps.
cubswin1oo's Avatar
Default awd
Correct, no awd in any gear when running. Awd lights up in all gears with key on not running. When the bike is running can't make awd light up. Just to clarify, the bike dies when put in reverse only, without the override switch on.
Old Apr 15, 2009 | 08:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
ya sounds like one or both of the trans.and the override limiter box is bad. try kerbbirds suggestion.
Old Apr 15, 2009 | 11:00 AM
cubswin1oo's Avatar
Thanks kerbird, I will try that and get back with yall. Probably won't be til this weekend.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Gtsordo
Jul 13, 2015 10:38 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
