1984 Honda 200ES runs like crap
Old Apr 15, 2009 | 10:12 PM
Jackball42's Avatar
Default 1984 Honda 200ES runs like crap
I just aquired a 1984 Honda 200ES Big Red and it runs like crap. It spits and farts and wont idle, I have to crack the throttle to keep it running. I installed a new plug, cleaned the carb, checked valve ajustment and they are all ok. The main needle in the carb was set to the wrong position so I reset it to the normal altitude positon. Still runs like crap. It seems to idle better with the choke on. I can drive it down the road without a problem but idle is the issue. Any help would be great.
Old Apr 16, 2009 | 08:24 AM
sdm111's Avatar
2 strokes or 4
I know you said that you cleaned the carb. but running better on choke is a sign that the pilot jet is clogged, if I were you I would get a rebuild kit.
Old Apr 16, 2009 | 08:27 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum Jackball42!
I agree with sdm111, your pilot jet is most likely still clogged..could you see light thru it after cleaning it?
Old May 3, 2009 | 08:26 PM
odysseyjunk's Avatar
you can get one through parts unlimited for 20 bucks or so..... a rebuilt kit that is.... will come with all jets as well as a float needle, which you could probly use at this point anyway
Old May 5, 2009 | 04:03 PM
Randy Stewart's Avatar
Hello atc's! I have a problem with my 1984 Honda 200es Big Red. The motor runs fine, for about 5 min. then fouls out the sparkplug with exesive black carbon. I can clean it off and it will run another 5 mins. and do the same thing. I have already cleaned the carburetor and made sure all ports and pilots are clean. I have even swaped carbs with another 200s, and the same thing happens... Any ideas of what to do next??
Old May 5, 2009 | 04:08 PM
If the needle wasn't in the normal altitude possition, " #3 ", then the main pilot is probably not the correct one either. You should have a "#95" and you probably don't. The main port is the little "cap screw" on the bigger of the two pilots inside the carb. good luck
Old Mar 9, 2010 | 09:21 AM
drjoe171's Avatar
I clean the slow jet with acupuncture needles an .008 guitar string seems to be too big acup needles are .005
njrider64
Jul 4, 2017 01:40 AM
blaze_master
May 26, 2015 11:18 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
lovinhonda
Jan 25, 2000 09:17 PM
