04 sportsman fill plug on flywheel/recoil starter cover
Old Apr 16, 2009 | 04:16 PM
musselmark's Avatar
Default 04 sportsman fill plug on flywheel/recoil starter cover
On my 04 sportsman I noticed a fill plug and a drain plug on the recoil starter/ flywheel cover. I went through deep water and water got into that area. I removed the cover to drain and noticed rust starting to form. Can I put oil in there to lube things up. What are the plugs for?
Old Apr 16, 2009 | 07:49 PM
TOP plug for checking timing,bottom for draining water out of recoil that accumulates.DONT put oil in the top hole! Best to take recoil housing off and physically clean up stator/flywheel and pulser coil.
Old Apr 17, 2009 | 08:30 AM
roy365's Avatar
what consists of a physicall cleaning for these components? what tools or things are needed?
Old Apr 17, 2009 | 07:56 PM
Contact/brake cleaner ,rags to clean up the mud and rust. best if you can pull flywheel and clean inside of flywheel and stator,BUT if cant,clean everything around area including the small pulser on left side of stator. Its a good time to grease up the starter bendix while you are at it. Just grease around plunging part of bendix and a little grease where it ride in bushing in recoil housing
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Shooterj2003
Jun 21, 2015 07:51 PM
DOAinNY
Jun 11, 2015 10:34 PM
garyt1975
Jun 5, 2015 08:53 AM
vipers
May 31, 2015 09:12 AM
