eton 70 viper
Old Apr 19, 2009 | 09:41 AM
vindell's Avatar
Default eton 70 viper
new to the minis, what are the easiest mods to do myself, would like to go a little faster ! just cleaned carb circuit, must of had a clog somewhere, runs much stronger. Had the cvt cover off, belt appears to be ok, however, belt seems to jump around alot, if that makes sense, loke its not running flat. any input would be appreciated.
Old Apr 27, 2009 | 03:22 AM
hotblooded's Avatar
We I am for sure not the smartest person on here but the clutches can deaden or bring to life your mini. Make sure there is no spacer in the front sprocket so it is closing all the was which is pushing your belt to the top. You want your belt to run up to a 1/4 or so of the top of the front clutch, you can take a sharpie and make a line on it, take it for a long wide open ride and see how far your belt is climbing. Making sure everything is clean in the clutch system is huge to and I am takling cleaning everything.
flyin-lowe
Dec 1, 2017 03:18 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
