Battery problems Yamaha Kodiak
Old May 8, 2009 | 11:35 PM
mike & sandy's Avatar
Default Battery problems Yamaha Kodiak
I have a yamaha Kodiak 4x4 utramatic ATV
the problem is that my battery is not charging I replaced the the battery with the one recommended, cleanned all the terminals and still the battery will not charge can any one help me with this problem or does any one have a suggestion what maybe causing this problem.
Old May 9, 2009 | 01:46 AM
Adonis's Avatar
Put a volt meter on the battery terminals with the engine running. You should get about 14 volts. If so, your charging system is fine, less and it could be a bad stator or voltage regulator.
Old May 9, 2009 | 11:21 AM
CraZySteve's Avatar
First off welcome to the forums! I love my Grizzly 450 (kodiak 450) great Quad!
Adonis has the right idea! Anyhow Here is a link w/instructions on how to download a copy of the 03-06 Kodiak 450 manual... That way if you have to replace the stator or voltage regulator
Manual
Free file hosting by Savefile.com
The link for the manual works but sometimes you just need to work it a bit...
1. Click the link in the Message
2. Scroll down to the Section in the BLUE Box that says "05-06 Kodiak 450" and Click "DOWNLOAD FILE"
3. Your download SHOULD start...
IF NOT
4. Scroll down to the Bottom.... where you will see
" Your download should begin shortly. If it does not, try Download file now "
That should do the trick
MrElussive
Nov 19, 2000 01:51 AM
MrElussive
Oct 26, 2000 02:30 PM
MrElussive
Oct 19, 2000 09:50 PM
aby11
May 7, 2000 07:58 PM
