newly modified eton 70cc viper
Old May 19, 2009 | 07:04 PM
vindell's Avatar
Default newly modified eton 70cc viper
Hello all, well just got a 70 viper for the kid's. Might have read previous threads? Anyway, had a koso cylinder,piston,ring's,koso intake and reed's,
keihn 20mm carb, uni,outerware,clutch kit and a drr pipe installed . Picked up yesterday. Extremeley happy with results!! Question is takes about 5-10 feet before the power hits, when it hits its hard. How do I get insant powerband. has to be in the clutch or variator? All work was done by kool kid's atv in NJ. What a professional, clean work.
Old May 19, 2009 | 07:58 PM
oldyeller's Avatar
I would call koolkidz and see what they recommend but I think you are on the right track..I would try some lighter rollers in the front variator and see if that helps...Stiffer springs on the rear clutch may also raise the engagement rpm above where your flat spot is..
Old May 19, 2009 | 08:02 PM
vindell's Avatar
thank's fot the input
Old May 20, 2009 | 12:49 PM
LT80's Avatar
LT80 Expert
rollers first.
Old May 20, 2009 | 11:09 PM
sand45's Avatar
2000 rpm springs and lighten your 3 clutch shoes .
Old May 24, 2009 | 01:31 AM
hotblooded's Avatar
Like I said before I am for sure not an expert but all the posts above seem to be a good combination of all. I know for me it was the 3 little springs or engagment springs that helped me the most off the gate.
Old Jun 15, 2009 | 07:28 PM
vindell's Avatar
when I Loosen screw on clutch, what happens next. I hear about a tool?
Is this something I can do on my own?. Have air tool's. Stock clutch with ? clutch kit springs. Not sure which color. Most of our hard riding is with my 30lb son and my 180lb body on this thing. I did notice it has a large yellow ( torque spring?). It goes about 10 foot then hang on. My 5 year old rides alone, thet's when the adjustable cdi comes in! Can keep it out of the powerband as she only rides around the property at this time.
Both children are really enjoying the atv thing, lol, so is dad
Old Jun 15, 2009 | 07:54 PM
oldyeller's Avatar
What screw are you talking about?..There is a 15 or 17mm headed bolt that will release the outer part of the clutch and you can remove it off of the shaft..After that the clutch shoes have a huge nut (39mm) that hold them together under spring pressure..You need to be holding it together so you can release the torque spring pressure gently after you remove the nut..IT's best to have two sets of hands if your a rookie and don't have a special tool...
Old Jun 15, 2009 | 08:01 PM
vindell's Avatar
ok, once of, then what. want it too hit hard off the line. Your first video is almost what i have now. koso head, 20mm keihnin, drr pipe, koso reeds. It seems to take off the same as yours did, just hit harder
Old Jun 16, 2009 | 07:12 PM
oldyeller's Avatar
I am still working on it..The etons have very heavy rear shoes in the clutch so a light wieght set of shoes will raise the engagement rpms quite a bit off the line..However in my case it did not help because now it is revving so high it is starting to shift gears already before the clutch engages..I have to try going back to the lighter tension engagement springs or a lighter set of rollers in the variator to hold it in low gear at the higher rpms...I got my light wieght clutch pack from Hetricks for about $60 bucks..
flyin-lowe
Dec 1, 2017 03:18 AM
kbazzy
Sep 26, 2015 11:26 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Jr Wagner
Aug 21, 2015 07:56 PM
