chinese atv parts.
Old May 23, 2009 | 11:00 PM
sdatv's Avatar
Default chinese atv parts.
hello everyone. i have just recieved two atvs. they are ata 125h, the sticker on the frame says taotao, so i believe thats the brand. the place i purchased them from said the engine is a honda clone. i had a couple issues with them and the place of purchase is sending out replacement parts. my questions are. is there a brand of the engine used in these? where is the best place to purchase parts? i can purchase through the place i bought but would like to check and see what else is out there. the engines are my main concern for parts. if any one knows the name of the engine do you know where i can get a parts breakdown and maybe evenif there is a manual out there someplace? they seem to be built pretty good. is the taotao brand the same as any other companies out there? if anyone can help me out i would appreciate it. thanks in advance. forgot to mention only thing i see on the engine is 124cc and a sticker with 157fm1 on it.
Old May 24, 2009 | 02:04 AM
HawkeyeRider's Avatar
Hello, and Welcome!! try this link..it might be helpfull
PartsProUSA Chinese Scooter ATV Parts & Accessories
Old May 24, 2009 | 09:10 AM
Sawyer's Avatar
On these Chinese ATV's the engines usally are not the issue if you maintain it properly. Typically mic atv's have poor air filters so you have to keep on top of that so you don't suck dirt in the engine. Also change out the shipping oil when you get it home and you should be good to go. The net is full of online parts suppliers for these things they all use common parts it just they are all mixed and matched differently depending on brand. What gives grief is elecltrical wiring, connections, rubber components, bolts (vibrating loose) and on many mic atv's the pivot points on the suspension are cheapo.
Chinese ATV's are cheap however some are "really cheap" and they cut corners in some areas like suspesion pivot points (no bearings just plastic bushings) and the amount of metal they use in some parts. I've had 3 mic kids atv's and by far the Jetmoto 150 has been the best machine, least amount of troubles, and best bang for my buck. However even it has some issues in areas that could be made better.
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum sdatv!
Im pretty sure the TaoToa factory is where the V-Bikes are made...Maybe the parts from a V-Bike will fit...
Old Jun 5, 2009 | 07:53 PM
damJerm
Guest
Posts: n/a
oops
ReconBayou
Oct 16, 2019 02:24 AM
fredrikrosen
Oct 29, 2016 07:56 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
01ssls1
Sep 22, 2015 06:50 AM
