04 Sportsman 500 smooth idle, but no balls
New to forum....
The 500 will idle fine but sounds like an out of tune 2-stroke snowmachine above about a third throttle. Pulled the plug MANY times to find a black dry plug, clean it, then it will run fine for 3 minutes then cutout, no power. Oil level fine (not overfull), connections good, good gas, pulled intake hose and B12'ed the carb and all intake tract, while installed so no vac leaks. It will rev fine in neu/park but in gear... crap, I can't even get it up the ramps into the back of the truck even if I wanted to take it it to the local stealer.
Bears are out and my time is short here so I could use any help ya'll are willing to provide ASAP!!!
Thanks
ATEAV8GN
North Pole, AK
Thanks
ATEAV8GN
North Pole, AK
Well, it happened to me in the past. (The reason was clogged air filter)
It looks like you have non suitable gas mixture . (Rich Mixture)
The carboned (black) plug may give you direction.
I would start with these checks:
Check the air filter. Clogged air filter may cause this symptom.
Check for open hose between the air filter and the carb
Check the hose between the carb and the engine.
Check the Carb choke. Make sure it’s not stuck.
All check out good.... took the whole intake tract apart all clean, won't run at all if I touch the choke, never use it unless its -20 or colder...
Any more ideas?
Air intake restricted ( inspect intake duct)
Air filter dirty or plugged.
Choke plunger sticking, or incorrectly adjusted choke.
Incorrect pilot air/fuel screw adjustment.
Faulty inlet needle and seat
Faulty inlet needle seat O-Ring
Float level too high
Loose jets
Worn jet or needle
Weak or damaged vacuum piston return spring
Fouled spark plug
Loose jets
Worn jet or needle
Fouled spark plug
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
