Carburetor drain screw leaking
Old May 26, 2009 | 05:35 PM
bentarrow's Avatar
First Things First!
Default Carburetor drain screw leaking
My book just shows the screw, anyone rebuilt a carburetor and know if the screw has a rubber o-ring. Can I just back it out and replace a seal. Any idea why the drain might start to leak?
Old May 26, 2009 | 08:08 PM
No o-ring on carb drain screw! If its leaking at the tube under the carb,could be needle and seat or float level causing the leaking? Carb bottom has an overflow tube for this purpose!! If fuel level gets up too high,will drain out the overflow tube.
Old May 27, 2009 | 07:46 PM
bentarrow's Avatar
First Things First!
Thanks for the reply, I went by the shop I use today but they went out of business over the weekend. Maybe I will try to rebuild it myself.
Old May 27, 2009 | 08:43 PM
TLC's Avatar
TLC
Here is a good how to on carbs, YouTube - how motorcycle and atv carbs work
It is long but mid way at 6min 50 sec he starts talks about what you need to know.
slowgsxr97
Mar 18, 2022 03:40 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Shainasmash
May 8, 2017 06:38 PM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
