200s conversion to 200x
Old May 29, 2009 | 04:38 PM
Eastcoastoffroad's Avatar
Default 200s conversion to 200x
I am attempting to put my hardware from my 1984 200s onto a 200x frame with rear suspension. The problem is I am unsure if it will work. I also do not know what parts I need for the rear suspension swing arm and such. If anyone has any input I would really appreciate it.
Old May 29, 2009 | 04:42 PM
Also on ebay I found the 200x frame the swing arm and suspension piston. What else do I need
Old May 30, 2009 | 07:01 PM
MadMel777's Avatar
i havent done one but it has been done ... ive heard it called a "auto X" do a search for it on 3 WHeeLeR WoRLD-Kickin' It into High Gear im pretty shure the motor is a direct swap in
Old Jun 1, 2009 | 10:06 AM
Chevynutt's Avatar
Default 200s-200x
I have a '86 200S, '84 auto 200X and a '85 200X. Few parts interchange other than the engine. Unless the 200x is almost complete it could get expensive. Ebay is the best place for parts if you are knowledgeable. The 83-85 200X frame is different than the 86-87 and parts won't interchange. If making the auto x you will need the older style round tube frame. You will have to use the 200x stator unless you change the wiring harness over from the 200s. The engine should bolt right in. Get a manual if you don't have one. There is a link on one of my other posts someone sent me for one online.
lonerider856
Oct 13, 2023 03:45 PM
dannytas
Sep 26, 2017 06:31 PM
shimanok2
Jan 29, 2016 07:37 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
