04 700 efi twin missing problems
Old Jun 1, 2009 | 08:42 PM
bizzycook's Avatar
Default 04 700 efi twin missing problems
Hello all, I was hoping someone might be able to help me out here. I have the 04 700 twin efi sportsmans quad, and it hasn't been rode that hard for quite a while, mainly just settin in the barn lately, but its spring/summer time so i decided to change the oil and filter. after doing that it's just made a few trips from the barn to the house, and all of a sudden it started missing. It will start up and idol just fine, but when i put it in gear it starts to missing and won't hardly even pull its self! I hope someone can point me in the right direction. I am pretty familiar with working on things, I just don't know where to start on some of the newer stuff. Thanks in advance to any and all help!
Old Jun 1, 2009 | 09:37 PM
You might check your intake manifold to throttle body for cracks,plus if ok could be a short in the t-bap harness on the throttle body. Might jiggle wires and see if improves,plus check all small sensor wires for abrasions or cuts. Harness repair kits are available for the TPS and T-bap sensor. Sensor failures are rare,usually the harness.ALSO if "just settin in barn',for how long? bad gas? Do you use a fuel stabilizer for extended storage? Plus if has original Champion or replacement Champion plugs,CHUNK em and replace with NGK BKR7ES
Old Jun 1, 2009 | 10:08 PM
bizzycook's Avatar
Originally Posted by Treacherous
Is Check Engine display on? Have you changed the plugs?
yes it is on, its been on for a long while. i had passed up my oil change requirements and forgot how to reset it from way back.
Old Jun 1, 2009 | 10:12 PM
bizzycook's Avatar
I will have to check the air intake manifold as i had checked my air filter and may have knocked something loose or cracked it while i was messing with it. It usually just stays in there for a week or two and i go out and ride it around a lil while, it usually doesn't have a lot of gas in it at any one time. and the thing that gets me is that it just started out of nowhere right after i changed my oil so i'm thinking maybe it has something to do with the intake manifold since i was putting a lil pressure on it to get the filter back on. and yes I do need to change the plugs, they are the orginals or probably the same as orginals.
Old Jun 1, 2009 | 10:14 PM
CHECK ENGINE light or are you referring to the WRENCH light? If wrench light,should go out after a short time when running ,IF its the check engine light and stays on,then possible elec problem on efi system.
Old Jun 1, 2009 | 10:16 PM
bizzycook's Avatar
just the wrench light, hell didn't know it had a check engine light on it
Old Jun 2, 2009 | 06:43 AM
Kerbbirds's Avatar
Check the spark plug boots and wires while changing plugs, both of mine came apart inside causing it to miss.
Old Jun 15, 2009 | 08:05 PM
bizzycook's Avatar
well i changed the plugs and no difference. oil wouldn't have anything to do with it would it? The plugs i took out looked dam near brand new on the end, no crude or anything. nice white electrodes. i shook around on the senser on top of the air intake but no big difference. It will set there and run just fine, but as soon as ya try to move it, it starts missing and won't even hardly carry it's self.
Old Jun 15, 2009 | 08:24 PM
bizzycook's Avatar
the only code that showed up was WA1E. I'm going to get some injector cleaner and fill it up with new gas and see if that helps
Old Jul 8, 2009 | 09:46 AM
AnywhereTom's Avatar
Check your plug wires, I had a similar situation on my 04 700 where it would idle fine but wouldn't run when the gas was applied, it was the plug wires where they pass by the frame had wore through, couldn't see it until I removed the wires themselves, also if your battery is low it will cause the loss of power when trying to give er the gas. Also the diagnostic code was telling me it was an injector code 51 I believe, which it wasn't - new plug wires and she ran good as new.
skinnyr6
Aug 25, 2023 02:18 AM
JoAnnS
Jul 23, 2015 02:18 PM
Captjay
Jul 23, 2015 12:33 PM
steveo612
Jul 11, 2015 08:35 AM
Jul 7, 2015 11:00 PM
