Where does this wire go?
Old Jul 7, 2009 | 09:15 AM
mikem74's Avatar
Default Where does this wire go?
First, thanks in advance for any help. I am glad I found this forum.
I changed the battery on my 99 sportsman 500. New battery in and no go. When i hooked the terminals back up I noticed a second black wire that is coming from the same path as the negative wire with a bolt loop on the end. It comes from the shrink wrapped "bubble" that the negative cable comes from. It was definitely hooked to something. Is this a ground? When i try to hold it to the frame to ground it it does not allow it to start. Any idea where this needs to go?
Old Jul 7, 2009 | 11:08 AM
mikem74's Avatar
If it helps...when i hook a jumper from another battery and ground the black jumper cable to the frame it starts right up.
Old Jul 7, 2009 | 11:11 AM
war1ock's Avatar
its a ground i think. try attaching it to the battery with the negative battery cable
Old Jul 7, 2009 | 02:05 PM
mikem74's Avatar
Ok so just hook it directly to the negative battery terminal?
Old Jul 7, 2009 | 11:22 PM
war1ock's Avatar
yea. put that and the cable together and put the bolt through
Old Jul 8, 2009 | 10:13 AM
mikem74's Avatar
problem solved. I ran a ground wire from the neg terminal to the frame. Fired right up! Thanks!!
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
