Reaplcing Bendix starter drive
Old Jun 5, 2009 | 02:57 PM
dollar662's Avatar
Default Reaplcing Bendix starter drive
I have an 01 Sportsman 500 I need to replace the starter drive. Do I need t oremove the rotor ?
haynew says I do BUT Cylmer doesnt say I do. Just didnt want to get into it and find out I do
Thanks
Old Jun 5, 2009 | 03:18 PM
teamplayer's Avatar
Yes the flywheel needs to come off.
Old Jun 5, 2009 | 03:35 PM
dollar662's Avatar
Ouch ok thanks
Old Jun 7, 2009 | 01:13 AM
Tagawichin's Avatar
I have replaced two bendix drives on 99 sportsmans and did not need to remove the flywheel.
Old Jun 7, 2009 | 07:00 AM
dollar662's Avatar
really !! now thats good news
Did you just remove the recoil starter and the Bendix then slides out?
Old Jun 7, 2009 | 10:19 AM
Just wiggle the bendix out a little and some turning and twisting along with moving the flywheel around will enable you to get it out. Dont forget the washer behind the bendix that might stick
Old Jun 7, 2009 | 03:46 PM
dollar662's Avatar
Excellent ! I took all the bolts out around the receoil but it seems stuck on there pretty well still almost looks like sealant around it. Should it remove easy after bolts out if so I will see if I missed one or something
Thanks again
Old Jun 8, 2009 | 09:50 AM
dollar662's Avatar
any ideas sorry to bump just want to complete this today
Old Jun 8, 2009 | 11:34 AM
dollar662's Avatar
got it off, It was sealed all around outside edge not sure why past owner did that but good news is its off now : )
Old Jun 8, 2009 | 01:02 PM
dollar662's Avatar
ok I swapped the Bendix thats the good news bad news I still have same issue. If I go to start it it sounds like its just spinning and not hitting the flywheel. It will start abou 1 out of 4 or 5 times I try.
Also whats intresting is if I tighten th erecoil starter down and use elec start it just clocks but if I loosen each screw half turn on recoil start it will then try to fire up any ideas ?
