Reaplcing Bendix starter drive
ok I swapped the Bendix thats the good news bad news I still have same issue. If I go to start it it sounds like its just spinning and not hitting the flywheel. It will start abou 1 out of 4 or 5 times I try.
Also whats intresting is if I tighten th erecoil starter down and use elec start it just clocks but if I loosen each screw half turn on recoil start it will then try to fire up any ideas ?
both bushings are ok. What seems to be the issue is it doesnt open to engage the flywheel it just spins. What casues it to open?
Any idea how to fix it?
Same issue with tightening screws though when top 2 are fully tight it just clicks doesnt even spin. half turn back it will spin
Is this a new or used bendix? bendix uses centrifugal force to spin out and engage flywheel. Is spring in place properly in the bendix,counter weights ok? Does it spin out by hand and retract normally? Is bendix an OEM Polaris OR aftermarket? Can make a difference!
#15
its new I bought it from DB Electrical SKU SMU5003 NEW STARTER DRIVE POLARIS ATV,BENDIX SPORTSMAN 500 Heavy Duty SMU5003
BY hand if I spin in the oppisite direction it comes out and retracts normally.
I am not sure if the spring and counter weights are ok as I'm not what I'm looking for sorry
Thanks again for your help
#16
After looking at a diagram I realize I do not have a recoil gasket this must be why There was sealant around it. I will pickup a gasket today and see if that makes a difference.
This may also be why it wont fire when I tighten the screws as without the gaskey possible they go to far ?
#18
Heres an intresting part I found out last night. My battery died (3weeks old) so I jump it and while it was being jumped it worked as it should. But once the cables were off the starter would spin but the bendix didnt come out to engange the flywheel. That and when I fully tighten it doesnt even spin. Starting to pull my hair out on this one.
I might try the old one again and see if any differances
#20
its still under warranty so I will replace it
DO you know what the bushing part numbers are? FIgure might as well replace them while I have it open. I know one is 3083669 but cant find the other
Thanks again
Thanks again
