Prairie 360 speed sensor
Old Jun 9, 2009 | 06:11 AM
dwight7751's Avatar
Default Prairie 360 speed sensor
The code keeps coming back. I clean the connection for the speed sensor and seal with super lube paste. Works for a day or two and then problem is back. Any solutions?
Old Jun 9, 2009 | 02:53 PM
Hayashi's Avatar
What code are you reading?
Are you referring to a flashing belt or 4WD light
And how do you relate the code to the faulty speedo sensor?
Old Jun 10, 2009 | 05:50 AM
dwight7751's Avatar
I get the one second flash on the 4wd light. Do the tests as in the manual and I don't read voltage when I turn the rear wheels when jacked up. After I clean the connections, I read voltage there again.
Pehter
Oct 3, 2024 11:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
ReconBayou
Oct 16, 2019 02:24 AM
ReconBayou
Sep 23, 2015 02:41 PM
