99 sportsman 500
Old Jun 12, 2009 | 10:30 PM
coolbreeze69's Avatar
Default 99 sportsman 500
I have a 99 sportsman 500 that i just got, i noticed that the AWD light will come on but the front wheels do not pull, i have been reading around and saw that if the speedo does not work that the AWD will not work either, well my speedo doesn't work. My ? is this, does the speedo problem apply to the 99 models, or is to old? if it does apply, is there an overide i can do to make sure it is it? Also i noticed that the low range stopped working tonight, high is fine so is reverse, do you have any imput on that? thanks
Old Jun 12, 2009 | 10:38 PM
HARLEY_OWNER's Avatar
i have a 99 sp 500 and my speedo quit working but all four still spin... my light on my switch works but my speedo dont... maybe check your wires from handle bars to where they lead
also a wire to check on for the speedo is on the right side if your sitting on the quad... somewhere by the break caliper.. im not sure i havnt looked at mine yet either mine is in the shop getting clutch buttons
also check the hub fluid... maybe your armature plates are bad in the hubs... if the hub fluid is dirty then change it and try that... just a couple suggestions..
Old Jun 12, 2009 | 10:42 PM
Thanks man, i am going to check it out tomm, maybe it will be a quick fix, i traded a 05 suzuki ltz 400 racing 4 wheeler for it and some cash, don't know alot about it, but maybe it will be a something easy to fix, how do i check the hud fluid?
Old Jun 12, 2009 | 10:47 PM
there is a allen head on the hub... put it in N... and take the screw out... and roll it ahead or backwords to the 9 and 3 position.. fluid should then come out.. if it looks nasty change it...the hubs are magnetized and need good fluid to run.. thats the cheapest place to start and that should be done 2 times a year... i have gotten really good with the clutch system and if you wanna check you armature plates if it still dont work send me a pm and i'll walk you threw it... my 99 is a solid quad i wouldnt trade it off.. maybe buy another but i am gonna keep mine... let me know
Old Jun 12, 2009 | 11:10 PM
monster malibu's Avatar
My speedo quit working on my 99 also but the AWD still works.
Old Jun 13, 2009 | 11:29 AM
Jocko's Avatar
You realize that the Sportsman AWD works a little differently, right?
The front wheels will not engage until the rear wheels slip...I believe about 1/5th of a turn or something like that.
Old Jun 14, 2009 | 10:20 AM
thanks jocko, hiw would you suggest i try checking it? i have lifted it all the way off the ground, all 4 wheels, and the front never turned, so i figured it didn't work.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
