warrior new clutch
Old Jun 14, 2009 | 06:53 PM
m16a2's Avatar
Default warrior new clutch
I need a new clutch for my 01 warrior and was lookin on ebay and saw Tusk clutches and EBC clutches. The tusk one is like 20$ less than the ebc ones, and I was wondering which one I should go with. Has anyone used any of these clutch makers?
Old Jun 14, 2009 | 10:05 PM
91Warrior357's Avatar
dont go with tusk, there pos in most cases, ive heard some bad stories about them...get either OEM clutches or EBC, both are great.
Old Jun 15, 2009 | 01:30 PM
m16a2's Avatar
thanks. Also i was wondering you can run Amsoil SAE 20W-50 Synthetic Motorcycle Oil (MCV) High Performance Lubricant for Engines, Transmissions and Primary Chaincases, in the warrior? Is that ok for the clutches? I know it shows a pic of a harly motor on the oil, and they have clutches outside of the case.
Old Jun 15, 2009 | 05:51 PM
if on the back of the bottle it says JASO approved then its fine, otherwise it would be better using an oil that is JASO approved, using other oils can cause clutch slippage and stuff.
Old Jun 15, 2009 | 07:28 PM
m16a2's Avatar
yes it does thanks
API SG, SL/CF, CG-4; JASO MA/MA2; ISO-L-EMA2; API GL-1
Old Jun 15, 2009 | 07:50 PM
should be fine then, specially since its Amsoil, i dont think you could go wrong with using any of Amsoils products.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
