2003 warrior trouble
The gasket where my cylinder meets the engine case is leaking fuel and oil. is it possible to dissemble the entire cylinder jug as one unit without messing with the cam or timing gear so I can replace that gasket? Please any help would be great.
You shouldn't have to mess with the cam but you will have to remove the timing gear and timing chain to remove the top end. Really not that big of an issue though just a matter of removing the nut holding the timing gear on, sliding the gear and chain off, and then just replace the gear in it's original position. Then just the reverse when you go to install the chain again. Just make sure you tie a wire or something around the chain so the chain doesn't fall down into the case.
mrtidy
Feb 3, 2016 05:00 PM
