2003 warrior trouble
Old Jun 14, 2009 | 07:04 PM
ravenwarrior03's Avatar
Default 2003 warrior trouble
The gasket where my cylinder meets the engine case is leaking fuel and oil. is it possible to dissemble the entire cylinder jug as one unit without messing with the cam or timing gear so I can replace that gasket? Please any help would be great.
Old Jun 15, 2009 | 10:57 AM
Swerve's Avatar
You shouldn't have to mess with the cam but you will have to remove the timing gear and timing chain to remove the top end. Really not that big of an issue though just a matter of removing the nut holding the timing gear on, sliding the gear and chain off, and then just replace the gear in it's original position. Then just the reverse when you go to install the chain again. Just make sure you tie a wire or something around the chain so the chain doesn't fall down into the case.
Old Jun 15, 2009 | 11:12 AM
thanks...working on it now..
Old Jun 15, 2009 | 11:15 AM
Swerve's Avatar
Good luck ....
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
Bernhard
Sep 25, 2015 12:45 PM
