Wolverine 450 4x4 problems
Old Jun 15, 2009 | 12:22 PM
Hondarider27's Avatar
Default Wolverine 450 4x4 problems
I have a 07 wolverine 450 4x4 that is acting up. I noticed somtimes when i turn the key on and press the starter button it makes alittle pop and acts like the fuse blew. Everything including the dash goes dead. I have a pull starter on mine so i have to pull start it, and it starts up and runs fine and everything works fine again. Dash lights up and works. Then when i shut if off and try to restart sometimes it will start fine and somtimes it acts up and makes a pop and then i have to pull start it and soo on. There must be a loose connection somewhere, where should i check at? I checked around the fuse area and everything seems fine. Thanks for the help.
Old Jun 15, 2009 | 12:28 PM
mschillingii's Avatar
Always start with you battery, Work your way on the negtive(shorter and less wires) then follow your postives. Check tightness on every connection one just a little loose can be the problem. The pop you are most likely hearing is the starter senolid. its got enough power to kick the senolid but not turn the starter
Old Jun 16, 2009 | 04:10 PM
gtnwood1's Avatar
Check your main fuse. Mine did the same thing and when I went to pull the main out it came out with only one spade connected. Still cant figure why my lcd 's wont work though, the panel lights up fine.
Old Jun 17, 2009 | 10:32 PM
miassmaro98's Avatar
lcd's?
Old Jun 18, 2009 | 01:50 AM
nkkiegem123's Avatar
i had the same issue before and i just checked the fuse..and it worked fine after i fixed it.
Old Jun 18, 2009 | 11:18 PM
gtnwood1's Avatar
L.C.D. I have a digital dash and the back light is on but the Liquid Crystal Display is not...........the digits are not workin, no speed no hours no miles no clock etc....
Old Jun 19, 2009 | 12:44 AM
gtnwood i had the same problem and the dealer replace the whole gauge cluster.
Old Jun 19, 2009 | 06:28 AM
ross.graziano
Guest
Posts: n/a
Yeah I do serious mudding with mine like miassmaro and mine died out too, havent worried about it to much but I would like to have it back. I guess ill try to change the main fuse also. Miassmaro sounds like u may have been the victim of sumthing like I almmost was about 2 years ago, I went to the dealer cuz my horn stopped working on my SS and they told me it was gonna be like 800 bucks and they need to replace the whole system but I told them nah and I replaced the fuse for the horn and it worked fine and has for 2 years.
Old Jun 19, 2009 | 10:00 AM
gtnwood1's Avatar
Thanks Bro, if ya dont mind me askin what did that set ya back, I may just go without if it's to pricey.
Old Jun 19, 2009 | 12:43 PM
i have extended warranty so all i did was give the tech a $40 tip
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
