07 Sportsman 500 HO No Display Doesn't Start
I have a problem. I can't get any display on my panel. The battery is fully charged, Took it out to charge it and reset factory mode. Display came on for about 30 seconds. Then died. I have another machine that is the exact same and when you turn on the key you hear a clicking sound. As well as when you turn the key off they have done this since day one. The machine that is not working doesn't make this sound. Also it was rolled end over end a couple of times but has run since. I also don't know where the kill switch is this may be the issue.
Any and all suggestions would be appreciated
Hi Guys
We figured it out. It was a corroded connmection on the PDM which is located under the storage pod on the front between the rad and the winch. Cleaned the connections and everything fired up great.
Thanks for your suggestions.
whitty
67
Feb 24, 2021 02:52 PM
