Problem with my 08 Wolverine 450
Old Jun 22, 2009 | 11:06 PM
2008wolverine's Avatar
Default Problem with my 08 Wolverine 450
Sorry to ask a question on my first post here but yah.
I was out for bout three hours on the quad today, going to threw mud and water. and all a sudden the machine just shut off it started back up but it would just bog out if i gave it gas. So i turned the choke right up and i could drive it bout 1/4 throttle/30kmph anything over and it would die. it idles fine though. its the same in N or Park, i can give it bout 1/4 throttle then it dies after that.
whats wrong? any ideas?
thanks.
Old Jun 22, 2009 | 11:13 PM
bigfrdtrk's Avatar
either u sucked **** through the vent hose on the carb or uve got the same problem i do...i cant figure it out
Old Jun 23, 2009 | 08:57 AM
joaquin's Avatar
It hapened to me twice. It was the main jet dirty.
You have to loose the 2 carburator clamps, turn it 90 degrees to have acces to the lower part of it. Then remove the float bowl cap, and finaly remove the main jet and clean it. Mine had a small piece of wood once, and dirt the other time.
I will put you on a link the instruction to take the main jet out (with pictures) that i folowed when i did it.
WoodWarrior.com :: View topic - HOW TO - Change the main jet in your Wolverine 350
good luck,
Old Jun 24, 2009 | 05:11 PM
thanks guy, im thinking your probably right, ill give this a try thanks for your advice.
Old Jun 24, 2009 | 10:23 PM
Problem solved!! pulled her apart, was a small piece of wood in the main jet. THANKSS!!!
runs awesome again.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
